Re: Dieseling SMTA
Posted by Bob M on December 11, 2003 at 07:31:15 from (165.170.128.65):
In Reply to: Dieseling SMTA posted by Tom on December 11, 2003 at 07:08:41:
Make sure the carb idle mix is set properly. Set the idle RPM as low as possible - if the idle mix is right it should idle down to 375 RPM or so without difficulty. Before shutting down, idle the motor for several minutes before hitting the switch. Switching to a cooler spark plug will sometimes help. Switching to 91 or 93 octane gas helps too- but it adds unnecessarily to your fuel bill.
Or do what I do: Idle the motor, put the tranny in 5th gear and slowly release the clutch as you hit the ignition switch. The engine WILL STOP immediately!
Post A Followup
: Re: Re: Dieseling SMTA
