Farmall Tractors Discussion Board
Re: How much would YOU pay?
Posted by Phil Auten on October 06, 1999 at 04:54:08 from (206.175.72.226):
In Reply to: How much would YOU pay? posted by Rob in MO on October 05, 1999 at 19:56:34:
Rob,
I'd probably offer him $750-900 depending on just how bad the tires are. Replacing the rear tires could run you $500. Then you'd have as much in the tractor as it's worth. Super C should do blade work just fine if the engine is sound.
My 2 cents,
Phil
Post a Followup
: Re: Re: How much would YOU pay?
