Re: Re: Re: Well I better do the TA.
Posted by rebuilder on December 11, 2003 at 18:57:56 from (66.228.102.66):
In Reply to: Re: Re: Well I better do the TA. posted by paul on December 11, 2003 at 17:50:44:
Paul: To my understanding of Kelly's post he hears the noise with or with out the T.A. So problem should be elsewhere. If in your case the noise is only when T.A. is engaged then I would suspect yes there probably is gear damage or needle bearing inside primary(input) shaft is out. Also I have seen several T.A.'s come in to be rebuilt because oil level was not keep at proper levels. The needles in the planetaries seized! Those are fun projects. If you suspect T.A. gears are problem, BEFORE you split tractor, take off top cover of bell housing and you will be able to look directly at the gears, and T.A. clutch pack.
Post A Followup
: Re: Re: Re: Re: Well I better do the TA.
