Re: Re: Re: Re: shifting problems with 350D
Posted by Bob M on December 12, 2003 at 12:47:29 from (165.170.128.66):
In Reply to: Re: Re: Re: shifting problems with 350D posted by Mark on December 12, 2003 at 11:40:15:
Mark - I agree w/FarmallMD - you're unlikely to find a new shifter at your dealer. And if you do it will be spendy. A couple suggestions:
1 - It's simple to fix a worn shift lever end. Takes only a few minutes to build up the button with arc weld, then grind the weld metal into a workable profile. It doesn't have to be 100% accurate either - anything close to the original profile will greatly improve shifting.
2 - On my Super H, difficult shifting was caused by a missing cross pin and a wrong size (too small) pivot pin in the base of the shift lever. Was a simple matter to cut up a couple common bolts to make good replacement parts. The tractor now shifts gears like new. (However your dealer can probably provide these parts new at reasonable cost if needed...)
Post A Followup
: Re: Re: Re: Re: Re: shifting problems with 350D
