Re: Gotta be valve guides, right?
Posted by ScottyHOMEy on March 31, 2009 at 11:50:58 from (71.241.194.27):
In Reply to: Gotta be valve guides, right? posted by Jim Isler on March 31, 2009 at 11:37:33:
You could knock me over with a feather if you were losing any compression through the guides. Perhaps losing a little vacuum, yes, but not compression. Compression happens when the valves are closed. The only three places to lose compression with sound pistons and sleeves are at the valves, the rings and the head gasket
So no matter how good they "look" there's a good chance your valves and seats (coked, warped . . .) need attention and, what with the smoke, if it's blue, the guides and stems. How did you size your rings? They're not off the list yet, either did you stagger the gaps on them?
