Farmall Tractors Discussion Board
Re: Re: Re: Re: Paintin Red
Posted by Theman on October 06, 1999 at 09:44:56 from (204.149.23.2):
In Reply to: Re: Re: Re: Paintin Red posted by Steve on October 06, 1999 at 06:27:12:
I can't...but that doesn't mean I haven't blasted anyway. That grit goes EVERYWHERE. Make sure to cover all openings and keep your blast nozzle pointed away from seals and any bearing surfaces or machined areas where gaskets need to go. Be sure to clean all grease off first. Also, a painter friend said to be sure to tape off all glass gages with masking or black vinyl electrical tape. And foremost: wear a dust mask!
Post a Followup
: Re: Re: Re: Re: Re: Paintin Red
