Re: Re: Carburetor Packing Nut, what purpose does
Posted by rebuilder on December 15, 2003 at 12:04:40 from (216.241.135.159):
In Reply to: Re: Carburetor Packing Nut, what purpose does it s posted by rebuilder on December 15, 2003 at 12:00:32:
Aaron: Sorry I forgot to tell you the packing is to seal the gas from leaking out around the main fuel adjusting needle which is what goes through the nut and the packing. This way you can turn the needle either way without losing you sealing capability. If it starts to leak just turn the packing nut a couple more turns to jam the packing tighter and created a new seal.
Post A Followup
: Re: Re: Re: Carburetor Packing Nut, what purpose does
