Farmall 460 crankshaft
Posted by Paul K. on December 15, 2003 at 21:49:33 from (205.188.209.82):
Today I pulled the rod caps off and started to remove the pistons. I got five pistons out and when I went to remove the last one it had flopped over to the side of the rod journal between it and the block. I tried turning the crank backwards and it acts like it is binding up on something. I could move it in the direction of rotation but not the opposite way. Now I got the journal up against the rod and no way to go. Could anyone get me out of this bind. (no pun intended). Thanks, Paul
Post A Followup
: Re: Farmall 460 crankshaft
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
