Re: Grinding gears/ stuck clutch Farmall w4
Posted by Nebraska Cowman on December 16, 2003 at 04:02:26 from (65.172.142.97):
In Reply to: Grinding gears/ stuck clutch Farmall w4 posted by Jon on December 15, 2003 at 21:17:24:
have you tried towing it? or put in gear, lock the brakes and try turning the motor over with the crank. If it does not break loose you may have to take it apart. the cover comes off the top but you have to cuss the starter off. take one of the bolts out that it hits on and it will give you just enough room.
Post A Followup
: Re: Re: Grinding gears/ stuck clutch Farmall w4
