Re: Grinding gears/ stuck clutch Farmall w4
Posted by The Red on December 16, 2003 at 09:49:36 from (206.246.187.2):
In Reply to: Grinding gears/ stuck clutch Farmall w4 posted by Jon on December 15, 2003 at 21:17:24:
Old Red H's clutch sticks on occassion. First I warm up the engine then shut it down. I then set the throttle near idle and select either first gear or reverse and start it in gear. After I get it running, I advance the throttle and keep the clutch pedal depressed. The clutch usually releases within a minute or two.
Post A Followup
: Re: Re: Grinding gears/ stuck clutch Farmall w4
