Re: Farmall A. Can it be converted to Super A???
Posted by Bill on December 17, 2003 at 05:32:47 from (68.70.204.195):
In Reply to: Farmall A. Can it be converted to Super A??? posted by Tom Williams III on December 16, 2003 at 18:22:39:
As I answered yesterday, yes you can use Super A parts to convert an A. The A engine doesn't have an opening to install the pump. You can run it off the generator. The center housing and hydrualic will fit. No cutting or welding required. When it stops snowing I may be able to get to the barn and take a couple pictures if that will help.
Post A Followup
: Re: Re: Farmall A. Can it be converted to Super A???
