Re: Touch Control Leak on Farmall C
Posted by FC on December 17, 2003 at 07:32:40 from (66.84.205.26):
In Reply to: Touch Control Leak on Farmall C posted by Haas on December 17, 2003 at 07:02:57:
Haas, I remember your post, and think I replied. I found out the same thing you did. I tried for an hour to get it apart with the unit on the tractor and gave up, as I had some work to do with it. I just filled up the unit and went back to work. I am going to have to remove the unit and install soon though. I only bought one boot and o ring but since I am going to have to remove the unit I am going to go ahead and do both.
Post A Followup
: Re: Re: Touch Control Leak on Farmall C
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
