Re: Gotta be valve guides, right?
Posted by Brownie 450 on March 31, 2009 at 13:16:35 from (216.51.158.151):
In Reply to: Gotta be valve guides, right? posted by Jim Isler on March 31, 2009 at 11:37:33:
Is it blue or black smoke?? Maybe the carb is running rich. Is the air cleaner & hoses not blocking air into the engine?? How is the timing--on the money?? Valve lash is probably O.K. as the engine runs well. Look at all possibilities before pulling the head. Loosen up a couple of the valves & see if there is side play..
