Re: 8 volt battery
Posted by john d on December 17, 2003 at 18:51:02 from (205.188.209.82):
In Reply to: 8 volt battery posted by Denny Binkley on December 16, 2003 at 16:02:20:
I have charged mine with a 6 volt charger. Also have put it on 12 volts in the "trickle-charge" setting without problems. When charging any battery, it only takes a little too much voltage to cause some problems, so watch that ammeter on the charger! When the tractor is running, look at the ammeter and see if it is charging. If the ammeter needle is past 10 amps, your problem may be the battery, or something that's draining the battery when the tractor is off. The 6 volt generator is plenty capable of charging the 8 volt battery if the regulator is adjusted correctly. Cutting out at 9 volts may be a little low. You're going to get grief from some people about not staying with 6 volts, and hear all the stories about starting their tractor with 6 volts at -30 degrees in a blizzard. In fact, I have started an M at -20 with 6 volts. In stock confuguration, with good cables and conections, they will start. HOWEVER, once they've been "tweaked" with high compression pistons and pushed into the 50+ horsepower range, turning them over with 6 volts, warm or cold, can be a challenge. The 8-volt will spin it fine.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
