Re: To rebuilder smta ta
Posted by rebuilder on December 17, 2003 at 18:54:55 from (66.228.102.32):
In Reply to: To rebuilder smta ta posted by paul on December 17, 2003 at 17:49:04:
Paul: I done quite a bit of thinking on what might be the primary reason for your low side noise. I have to believe that since it only occurs when T.A. is engaged the problem is contained within the T.A. Perhaps somone else on the forum can back me up on this. My gut feeling right now is that a needle bearing is going out possibly inside the primary shaft(sun gear). I have never seen the two bearings in the carrier go out, just show some wear. Is the throwout bearing bad can you tell? The only other answer would be the ramp cams have become soo worn that they are grinding against the carrier when engaged. I have seen the needles seize inside the planetary gears but only rarely, and if you have taken good care of changing the oil and keeping the level up this should not be your problem. SO- I guess I haven't helped you a whit in narrowwing down the problem without tearing the T.A. apart. Check the Throwout bearing while you have the top plate off although you may not be able to tell easliy if it is going out. Also- before you split the tractor, try doing what Kelly C did and remove the belt pulley or the plate covering the belt pulley hole in the speed transmission tho get a look at any damage to the gears that may be there(see posts a couple of days ago)_.This may give you some more clues to your noise. Good luck and don't hesitate with more T.A. questions.!
Home
| Forums
Today's Featured Article -
Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
