Re: Re: Took out pistons on cub......what do i nee
Posted by Jonathan Mirgon on December 17, 2003 at 19:53:41 from (205.208.129.213):
In Reply to: Re: Took out pistons on cub......what do i need to posted by Farmall-Nut on December 17, 2003 at 18:06:35:
If you want to do it right I would recomend that you , have the bore on the block machined to oversize, replace the piston and rings, have a machine shop check the head and reface and or replace the valves and install hardened valve seats in the head. Have the machine shop grind the crankshaft and replace the main and rod bearings. I am sure that it would take a lot less than this to get it running again, But if you want it to run for another 30 years this would be the right way to do it ! If you need any help feel free to e-mail me at Mirgon@ohiohills.com. I would be happy to help !
Good luck
Jon Mirgon
Post A Followup
: Re: Re: Re: Took out pistons on cub......what do i nee
