Re: Rear Blade on M
Posted by Dave in CT on December 18, 2003 at 16:09:05 from (204.60.63.249):
In Reply to: Rear Blade on M posted by cheg on December 18, 2003 at 06:18:46:
I located a snow plow frame and blade (seperately) for my '47 H fairly easily and inexpenively - the two came to about $80. The frame required fabrication of a couple of 'ears' to match the mount points on the blade. Once this was done, the mounting of both the frame and blade was very easy for this neophite. Using some 3" angle, I extended the draw bar to form a platform for a rock box. The added rear weight came to 460 pounds which I'm guessing is around the weight of the frame and blade. Even though I need to change the angle of the blade manually, the system works admirably. I've plowed 6" of really wet snow on a moderate grade with nary a slip. I don't know if this would be more trouble than what you're considering but I thought you might be able to use an as-experienced plow-forward account.
Post A Followup
: Re: Re: Rear Blade on M
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
