Re: Re: Re: Farmall C Carberetor? Which one do I
Posted by CNKS on December 18, 2003 at 20:02:21 from (207.178.96.212):
In Reply to: Re: Re: Farmall C Carberetor? Which one do I have posted by Tommy H on December 18, 2003 at 19:37:39:
If everything is original, there will be a hole in the left rear of your hood for the filler neck for the gasoline starter tank (distillate/kerosene tractors start on gas then switch to distillate/kerosene when warm). I have seen distillate carbs on original tractors without the distillate tank. The main jet adustment on a distillate carb is as you have described. The needle in front is the idle mixture.
Post A Followup
: Re: Re: Re: Re: Farmall C Carberetor? Which one do I
