Re: Re: Farmall C Distillate engine? Setup?
Posted by Tommy H on December 19, 2003 at 12:07:59 from (65.140.19.146):
In Reply to: Re: Farmall C Distillate engine? Setup? posted by rustyfarmall on December 19, 2003 at 11:38:07:
I just came in from getting the carb off. I got a good look at the fuel set up and ill describe it for you.
Big tank has large (tall) sediment bowl directly under it. Fuel hose coming off of bowl, behind air cleaner, acrosss carb and into elbow on front of carb. Removel of elbow exposes a wire fuel strainer inside the carb body. The carb has 1 float inside with 2 float bouys. Has a needle adjuster on bottom front, and on up top o nthe top part neck, facing down at an angle. The petcock i mentioned is a drain for the bowl. The gasket is destroyed and im not going to bother makign a new one, seeign as how it cant be started due to the 12V coil ignition and holey intake.
The Weld on the side of the block is larger than I thought. It spans about 10" straight across the block, directly behind the carb. IT doesnt appear to have been leaking.
Post A Followup
: Re: Re: Re: Farmall C Distillate engine? Setup?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
