Slow drop on 656 3 point
Posted by Dave J. on December 19, 2003 at 19:15:48 from (64.12.97.12):
My 656 gas has a slow drop 3 point in the cold weather. Want to plow, not wait for an hour for the hy-tran to warm up. Had the local IH shop put all new O-rings in the valve assy, new filter, 16 gallons of new fluid. The hitch works OK when the fluid warms to about 75 degrees. This takes too long just idling. About an hour. Covered the oil cooler with a piece of cardboard. Tried dipstick and magnet type heaters with no luck. What do all you other rear blade snow plowers do in the cold?
Thanks, Dave J.
Post A Followup
: Re: Slow drop on 656 3 point
