Re: how to check coil
Posted by buck on December 20, 2003 at 10:13:37 from (209.240.205.63):
In Reply to: how to check coil posted by o4terry on December 20, 2003 at 07:15:23:
Yes they can be good one second and bad the next. Shadetree method is to connect + side of coil to + side of battery with jumper wire and provide jumper wire a few feet from - side. With the primary(large wire that goes to distributor) held firmly about 1/4" from - momantarily touch -of coil to -jumper wire. If coil is good you will get a good spark off the primary. This is actually duplicating in function of the points in slow motion.
Post A Followup
: Re: Re: how to check coil
