Re: Fixing Fuel shut-off valve on a '47 H - Part 2
Posted by Bob on December 21, 2003 at 18:29:03 from (66.163.134.177):
In Reply to: Fixing Fuel shut-off valve on a '47 H - Part 2 posted by Dave in CT on December 21, 2003 at 15:29:17:
The rubber ring and/or packing are for external leaks right at the stem of the shut off valve. You problem seems to be the valve not shutting off the flow of gasoline to the carburetor. Is this correct? If this is the case, your valve may be internally pitted or damaged, or may have a piece of crud jammed in it. Have you priced a new valve? While it may cost a few bucks to replace it,it's sure better than having fuel leak into the intake all the time. The needle valve in your carb, should prevent this, but until you get the carb. fixed, you need a funcioning fuel shutoff. Even when you have the carb. tuned up so it doesn't run over, shutting the fuel off at the tank during periods of non-use is sure a good idea.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
