Re: Re: Re: hard starting 756 diesel
Posted by Hugh MacKay on December 21, 2003 at 18:45:39 from (64.228.12.113):
In Reply to: Re: Re: hard starting 756 diesel posted by corey lichty on December 21, 2003 at 18:00:48:
Corey: Do you know how much horsepower your tractor is putting out right now? Does it handle it's loads well on hills? Is it hard to keep it running at low rpm? This blue smoke you speak of does it stop when tractor is warmed up to operating temperature?
Post A Followup
: Re: Re: Re: Re: hard starting 756 diesel
