Re: Re: Re: Removing bearing from axle with retain
Posted by gene b on December 22, 2003 at 03:06:32 from (67.1.109.54):
In Reply to: Re: Re: Removing bearing from axle with retainer o posted by Larry Kastens on December 21, 2003 at 19:39:11:
When you removed the nut on the inside and the four capscrews by the hub the axle should slide out then the bearing should be easy to remove as the gear will slide off the splined shaft. You do have the bottom pan off also i take.
Post A Followup
: Re: Re: Re: Re: Removing bearing from axle with retain
