Just a neoprene rubber shield (umbrella) that fits on the valve stem and mostly covers the top of the guide. Sold by stem size mostly. Perfect Circle style are more complex and have a metering system, and a teflon bushing at the top. These clamp on the top ov the guides, and ride on the stem. They are designed to pass correct oil to lube the stem, and not so much as to allow sucking of oil. Even IH sells them ! But easily found in parts stores. for applications. The PC seals may need the machining of the valve guide outer diameter to allow installation, so the umbrella seals can be used W/O machining or head removal. They just prevent oil from running down the stem in mass quantities. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
