Re: Using an original 6V switch with 12V lights on
Posted by Bob M on December 22, 2003 at 04:51:25 from (165.170.128.66):
In Reply to: Using an original 6V switch with 12V lights on a ' posted by Dave in CT on December 21, 2003 at 22:45:29:
Dave - The 4 position light switch works fine on 12 volt conversions - I've done it many times. Both the L and H positions will be the "lights off" position; D will light the headlights dim (accomplished by reducing the voltage to the front lights) and the rear light bright; B will light all 3 lights bright.
If you use the old switch install only standard tractor-type sealbeam headlights - not aftermarket halogen (55 watt or higher) lights! Reason: The halogen's higher current draw will overheat the dimmer resistor could perhaps start a fire.
Post A Followup
: Re: Re: Using an original 6V switch with 12V lights on
