Re: MW Pump
Posted by Dave in WV on December 22, 2003 at 08:21:53 from (205.188.209.82):
In Reply to: MW Pump posted by Nebraska Cowman on December 21, 2003 at 13:50:05:
Yes- To remove with out taking pump apart,remove
sloted drive wheel from rear of pump.Should be a
small tension ring on end of shaft to keep it from falling of.But on most theres no way it will fall off.I rigged up a puller to remove as there
is keyway on shaft and very tight to remove sometimes.Seal is exsposed now take a small sharp punch put 2 holes in seal,screw 2 metal screws in holes and pull with pliers.For front seal remove drive gear and 4 bolts in front plate,seal comes out on pump side of plate.Hope this helps.
Post A Followup
: Re: Re: MW Pump
