Re: Farmall 140, front weights and 1 pt corn plant
Posted by Hugh MacKay on December 23, 2003 at 14:46:07 from (216.208.58.136):
In Reply to: Farmall 140, front weights and 1 pt corn planter posted by Kirk Affeldt on December 23, 2003 at 14:14:49:
Kirk: I've planted a good many acres of corn with 130 and two different corn planters, on one point fast hitch I had an IH with 250 lbs dry fertilizer and each seed hopper held a bushel. I currently have a John Deere planter basically same setup. I don't even use wheel weights. I also have a sprayer that holds 60 gallons. I quite often fill it and go spraying.
Post A Followup
: Re: Re: Farmall 140, front weights and 1 pt corn plant
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
