Re: Super MTA, MD-TA, W6 WD-6 Power
Posted by Mark on December 23, 2003 at 15:07:13 from (161.184.196.153):
In Reply to: Super MTA, MD-TA, W6 WD-6 Power posted by D.A. Buchan on December 23, 2003 at 12:38:50:
Diesel will always outpull gas, unless you have a high rpm gas screamer with lots more room for rpm drop. Diesel has way more torque, therefore takes alot more force to lower the revs than a gas. I just broke up 20 acres with a 10 foot ih deep tillage and my wd 6. It was a good pull, every so often the cultivator would hookup a bit and lift the front end of the tractor off the ground. I would not even attempt to do this with my w 400 gas. Gas makes a better run around light duty tractor due to ease of starting, lighter weight and less warmup/cooldown time. But you will never beat a diesel for heavy field work and long life.
Post A Followup
: Re: Re: Super MTA, MD-TA, W6 WD-6 Power
