Re: Re: H - Drilling out fender bolt holes
Posted by ET on December 23, 2003 at 18:26:52 from (64.19.91.176):
In Reply to: Re: H - Drilling out fender bolt holes posted by rustyfarmall on December 23, 2003 at 13:20:12:
The axel housing is cast iron so the rod for steel is not going to stick to cast iron. I use E6011 rod and keep putting a spot of weld on the bolt untill it is built back up to the surface of the housing then I weld the nut on. I have gotten out bolts broken off 1/2" below the surface like this.
Post A Followup
: Re: Re: Re: H - Drilling out fender bolt holes
