Re: How do you change the fan belt on an H ??
Posted by Bill Smith on December 24, 2003 at 12:04:28 from (63.147.130.86):
In Reply to: How do you change the fan belt on an H ?? posted by Santa , Merry X-mas on December 24, 2003 at 10:51:57:
Little John is correct. I believe first and foremost you will want to remove the hood so you can see better at what you are doing. The front half of the pulley is actually a threaded ring that will turn one way to loosen and the other way to tighten. There is a set screw that screws into a groove to keep the ring from turning on its own. You will need to loosen the nut on that set screw and loosen the screw (I would take it clear out to insure that it is out far enough). This will enable you to turn the ring. Be careful because the ring is caste iron and can be broken fairly easily. You may want to clean exposed threads and spray on some WD-40 before trying to turn the ring. If the old belt is broke clear into, shouldn't be hard to get it off. You may want to compare it to the new one for size. Thread the new belt over the fan blades. Tight fit but should go inbetween the hand cankshaft and the crankshaft. Place on the adjustable pulley first. Loosen the ring untill the belt can slide onto the crankshaft pulley. Then tighten the ring untill the belt has proper tension, rotate ring to closest groove and then put the set screw back on.
Home
| Forums
Today's Featured Article -
The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
