Re: Re: H - Drilling out fender bolt holes
Posted by Bill Smith on December 24, 2003 at 12:24:53 from (63.147.130.86):
In Reply to: Re: H - Drilling out fender bolt holes posted by Jim on December 23, 2003 at 18:54:36:
I would sure advise the welding method first. It will likely work and if not you can always do something different. Thank about it. If the bolt is seazed up enough to twist off, stands to reason that a smaller around easy out will snap just as easy. The friction of a drill bit is much less. I can't explain what the heat does when welding, but seems to loosen the bolt up as it was never seized most of the time. Well, anyway, good luck in whatever you do.
Post A Followup
: Re: Re: Re: H - Drilling out fender bolt holes
