Re: smta throttle cover
Posted by rustyfarmall on December 25, 2003 at 06:48:05 from (216.248.75.186):
In Reply to: smta throttle cover posted by paul on December 25, 2003 at 06:05:53:
Yours might be the aftermarket friction type lever, versus the original equipment type, which did have a sort of dome shaped cover with notches for the lever to set in.
Post A Followup
: Re: Re: smta throttle cover
