Re: 301 combine motor in a 460
Posted by E Je on December 25, 2003 at 08:07:35 from (67.31.155.27):
In Reply to: 301 combine motor in a 460 posted by Family Tradition on December 24, 2003 at 14:56:59:
Must change front motor plate & timeing gear case to tractor type .Use cast oil filter base and change the bypass holes easy to do.Rear motor plate off of tractor and flywheel will bolt right on will have to use two bolts instead of studs where their not thearded.Cast filter base allows steering shaft to pass by engine and frame.
Post A Followup
: Re: Re: 301 combine motor in a 460
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
