Re: farmall 300 electrical problem
Posted by Bob M on December 25, 2003 at 19:33:36 from (66.66.126.128):
In Reply to: farmall 300 electrical problem posted by howie on December 25, 2003 at 17:48:55:
Howie - Most likely the cutout relay in the regulator has stuck closed. To test, reconnect all the wiring and the battery, then pull the wire off the "GEN" terminal on the regulator. If the ammeter returns to 0 with the GEN wire removed it's time for a new regulator.
Post A Followup
: Re: Re: farmall 300 electrical problem
