Re: TA and Clutch adjustable links
Posted by Brian in MO on December 26, 2003 at 00:51:56 from (69.21.75.16):
In Reply to: TA and Clutch adjustable links posted by Bryce Andreasen (Magnum) on December 25, 2003 at 20:51:41:
Bryce, the main clutch should move the ta to the low side when pushed all the way in, if they do not then the transmission will be next to impossible to shift when on any slope at all (you usually have to pull the ta back to shift them when they are not adjusted right) and as others on this board have said before "with ta's adjusted close is not good enough". Brian
Post A Followup
: Re: Re: TA and Clutch adjustable links
