Re: Electric trailer brakes
Posted by DHuth2 on December 26, 2003 at 11:57:54 from (198.81.26.75):
In Reply to: Electric trailer brakes posted by Charlie on December 26, 2003 at 11:18:06:
Smoke almost always indicates a short circuit. A bare wire rubbing the Frame. You need to verify you used the proper color code for the controller and vehicle hook up. I always use a 20 amp reset circuit breaker between battery and controller when installing. This will eliminate burning out controller.What brand of contoller is it?I would guess on the info you supplied that you wired it incorrectly. Test your wires from controller to bumber plug for a short(ohmmeter). Let us know what You figured out.
Post A Followup
: Re: Re: Electric trailer brakes
