Brake Bands gone, Seal gushes fluid!
Posted by Tommy H on December 26, 2003 at 15:03:31 from (65.140.19.33):
I pulled the right side brake cover off my C, The brake material was gone except in a couple spots, and the rivets were worn flat in others. Im gonna need 2 of these suckers, where can I find them, and about how much are they?
Also, I pulled the drum off, and as soon as Idid that black tranny fluid started coming out of the shaft area. Put the drum on, and its ok...is the seal shot, or is the drum part of the seal?
On a better note, I pulled the starter and the teeth on the ring gear and the starter gear were almost not worn at all.
So, my list of things to replace grows...
Magneto
Starter Rod assembly
Starter Switch
All lights
light switch
ignition switch
Manifold
Carb Kit
2 Brake bands
PTO seal
Engine Gasket Set
Muffler
Install Water pump, thermostat and hoses
Base for instrument tower
Seat pan
Seat braket
Shock
Spring
Tool Box
PTO Cover
Drawbar unbent...
Steering Wheel
Sandblast
Paint...lol
Post A Followup
: Re: Brake Bands gone, Seal gushes fluid!
