Re: clamping ta clutch for removal
Posted by rebuilder on December 26, 2003 at 17:53:34 from (66.228.102.71):
Paul: The T.A. PPA(pressure plate assemblies) I have put in are already pressed together and held with just a boltX3. My thoughts are you should be able to put the PPA in some sort of press with a plate across the release bearing fingers, press together and insert bolts(make sure you can insert bolts while PPA is still in the press).
Post A Followup
: Re: Re: clamping ta clutch for removal
