Re: H Magneto Impulse.
Posted by Diesel Don on December 27, 2003 at 12:16:39 from (206.40.117.242):
In Reply to: H Magneto Impulse. posted by richard on December 27, 2003 at 08:23:37:
There is a possiblity that the impulse pawls and/or the pins they catch on are worn and throwing the impulse timing off. The point cam rides directly on the rotor shaft so it can't change. To inspect the impulse coupling, you will need to pull off the nut that holds the cover on, and carefully pull the impulse coupling off of the shaft. Check the corners of the pawls for wear and check the pin. If the pin has a divit worn in it, you can drive it out with a punch and turn it around to an unworn area and drive it back in. Feel free to e-mail me directly with your questions. I recently rebuilt an H4 mag and got to know them fairly well.
Post A Followup
: Re: Re: H Magneto Impulse.
