Battery Charging Problems - What's Next?
Posted by RandyMcC on December 27, 2003 at 13:49:20 from (24.91.32.192):
Hello all, I have followed the advice on the forum and I am still having charging problems on my '50 C. My battery is always low unless I do a 2amp charge overnight. When the engine is running at half throttle/higher the ammeter indicates a positive charge, however the ammeter needle oscillates wildly. When the engine is not running and the ignition or lights switch is on the ammeter shows discharge and the needle is steady. The problem is not related to engine vibration. Any ideas on what my problem is?
Post A Followup
: Re: Battery Charging Problems - What's Next?
