Re: Re: Re: Farmall Super A
Posted by Hugh MacKay on December 28, 2003 at 08:59:10 from (209.226.247.42):
In Reply to: Re: Re: Farmall Super A posted by HighPockets on December 28, 2003 at 06:14:44:
High Pockets: It sounds to me as though you have too much oil in the transmission. They are only designed to hold 5 quarts. The fill level plug is just below the forward end of the left fender, on the side of transmission case. These offset tractors get very messey if over full of fluids, as they will expell it down to proper level.
Is the hole you are speaking of almost directly below the gear shift lever on the bottom side of transmission case? May be a shade closer to rear of tractor.
Post A Followup
: Re: Re: Re: Re: Farmall Super A
