Re: Re: 656 v.s. 4 bottom plow
Posted by Hugh MacKay on December 28, 2003 at 13:59:40 from (64.228.11.2):
In Reply to: Re: 656 v.s. 4 bottom plow posted by sammy the RED on December 28, 2003 at 13:33:42:
sammy: In diesel they are exactly the same 282 cubic inch, 540 pto at 1800 rpm. I pulled a NO. 60 - 4x16 plow for several years with 560. Later I went to a semi mount plow Model NO. 510 - 5x16. I pulled that with 656 clearly because of 3 point hitch. I put well over 10,000 hours on each of these tractors. The 560 does have an edge on drawbar pull as it is heavier.
I might also add the diesel pump was turned up on my 560 for more power on field cultivator and forage harvester. However from factory they are very close.
Post A Followup
: Re: Re: Re: 656 v.s. 4 bottom plow
