Re: Re: Re: 560 gas question
Posted by Matt Clark on December 29, 2003 at 05:21:12 from (12.30.136.108):
In Reply to: Re: Re: 560 gas question posted by skip on December 23, 2003 at 13:56:42:
Skip:
Sorry for the delay...Christmas break here at work. Anyway, you've probably already figured out that the gasket is pretty simple to make. Use a few different rifle casings to punch out the screw & jet holes and you're in business. Be careful, as I learned from experience that you can't make several generations of gasket in a row. It just keeps "growing", and eventually, it interfered with the float...my mistake. Just make sure everything clears.
I've got a few hydraulic leaks I've been working on, but for the most part, I've got them cleaned up.
When you change the hy-tran, be sure you've got a BIG container. It holds 16 gallons, and there's no valve, you just pull the plug and out comes a 1 inche stream of fluid, under lots of pressure just from the sheer amount of liquid. I use a half a plastic drum cut to fit under the drawbar/PTO.
Hy-tran filter is easy to change, and clean the metal screen w/carb cleaner or gas.
I've been meaning to change the temp guage on my tractor for a long time, just haven't done it yet. Let me know how you get along and I may learn something too. This is my first tractor, and I've never done much wrenching before I bought it. I've already had this thing split for clutch changeout and the top off the transaxle to retrieve a dropped bolt...long story, just suffice it to say that when you pull the access panel off to add hy-tran fluid, always remove the bolts and washers and put them in a safe place BEFORE you pull that plate off.
Post A Followup
: Re: Re: Re: Re: 560 gas question
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
