Re: Unknown ball bearing - H Carb rebuild
Posted by Wayne Swenson on December 29, 2003 at 20:45:37 from (66.228.234.78):
In Reply to: Unknown ball bearing - H Carb rebuild posted by Dave in CT on December 29, 2003 at 18:19:47:
The "dent" the others are referring to is in the choke shaft about 1/4" in from the lever. Put the spring & ball in the hole in the carb air intake (lightly lube) and press the ball into the hole then slide the shaft in. Now you can re-install the choke plate. Check that the tapered edge of the plate matches the air passage. Leave the screws slightly loose and close the choke to allow the plate to center itself in the opening. Now tighten the screws firmly and clinch or deform the end of the threads so the screw cannot back out and end up inside a cylinder. Red or blue Loctite will work also. Be sure ALL jets & passages are clean so you only need to do the job once. Good luck.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
