update- super m meets 12 volts
Posted by scotc on December 29, 2003 at 21:38:36 from (162.39.3.178):
I put a 12v battery in the sm back in june, and got into the archives tonite and saw there were several people who had questions about it. I dropped the battery in and hooked it up positive ground, wired a chrysler-type resistor in the battery line to the coil, and its been starting ever since without boosters or towing. The miss I had was appearantly due to the coil being fed the full 12 volts. The ammeter is still reading 20-25 volts charging at WOT (may explain all those fried 6v batteries). I've got new lights, a flasher unit, signal lamps, and switches to outfit it with lights, also contemplating rewiring the whole tractor. For my flashers I am trying to come up with brackets that will hold them out above and slightly in front of my tires so that I will also have a place to stand when I need to fill it from gas cans, bolt-ons, of course.
Post A Followup
: Re: update- super m meets 12 volts
