Farmall Tractors Discussion Board
Re: Cub Low Boy 154
Posted by Harold H on October 08, 1999 at 10:49:41 from (207.244.59.17):
In Reply to: Cub Low Boy 154 posted by Carl N. on October 08, 1999 at 03:21:53:
Carl,
The 154 does have the belt driven starter/generator which can be expensive to repair. The pto is also belt driven which must be kept in proper adjustment to avoid problems. The steering linkage is ok for smooth type mowing but is a little weak if abused. All of these things considered, the Cub 154 Lo-Boy is still and excellent grass cutting rig. Price depends on your area. The tractor was available with or without 3 point hitch and with either regular tires in either R-1 or smooth tread or flotation tires with smooth tread. It was rated either 15 or 16 hp. There are several small 3 point implements that will work with it. However remember the Cub 154 Lo Boy was designed to be a lawn or landscaping type tractor whereas the Farmall Cub was designed to be a farm tractor.
Harold H
Harold H
Post a Followup
: Re: Re: Cub Low Boy 154
