Re: IH 684 with 2250 loader
Posted by JB on December 30, 2003 at 10:44:19 from (24.157.143.220):
In Reply to: IH 684 with 2250 loader posted by john on December 30, 2003 at 06:40:43:
My brother had the same problem with 2250 loader on 495 and it was leaking through the bucket cylinders. He had the cylinders replaced twice all under warranty. The last set of cylinders appear to be good. Problem was machining inside cylinders was rough and would destroy the "O" rings on the ram. The only other problem could be in the control valve. If you have quick attach couplers, you could swap control valve with bucket and see if problem follows valve or cylinders.
Hope this helps
JB
Post A Followup
: Re: Re: IH 684 with 2250 loader
