Re: super M stuck in gear?
Posted by Donnie on December 30, 2003 at 20:34:46 from (68.73.157.221):
In Reply to: super M stuck in gear? posted by fred on December 30, 2003 at 20:26:00:
Take the shifter out of the top of the tranny. (You'll have to knock the pin out that hold the shifter in. Its at the base of the shifter.) Take a long screw driver and put it back in neutral. Put shifter back in, put you pin back in, you can put a large hose clamp around the base until you can get to an IH dealer to get the cute little caps that go on each side of the pin.
More that likely the ball on the end of the shifter has wore enough to let it slid by the rails. I've welded them up and ground them back round and it helps. Hope this helps.
Post A Followup
: Re: Re: super M stuck in gear?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
