Re: H sector gear
Posted by Larry in CO on December 30, 2003 at 21:31:15 from (32.97.110.142):
In Reply to: H sector gear posted by gary v on December 30, 2003 at 18:04:48:
Gary,
Looks like this question slipped by everybody, so I'll take a stab at it. Assuming you have the worm gear out, this is the way I did it on my H. First I jacked the front of the tractor off the ground an inch or so. Then I loosened the nut on top of the sector gear so the top of the nut covered all the threads on the spindle. Put a block of hardwood over the nut and whack it a couple of times with a big hammer. This will loosen the gear most of the time. Let the tractor down on the ground and remove the nut. Now you can lift the sector gear off. Hope this helps.
Larry
Post A Followup
: Re: Re: H sector gear
